jerseyjim's avatar
jerseyjim
Change the oil in the differential?
2001 gassser, Ford, 54000 miles. Recently my mechanic suggested changing the oil in the rear/pumpkin/differential. Said there could be rust in there...and it would be a good PM. (anyway).
I've NEVER done this to any motor vehicle I've ever had...even those pickups with 150,000+ miles on them.
Opinions?
  • With a vehicle that age I would also change all belts/hoses/fluids period. You eliminate or reduce anyway many future problems. Tire check age/condition.
  • 15 years old time to change it.
    Replace with synthetic and will be the last time you will need it done.
    Unless you keep it for another 15 + years.
  • I'm sure there are a lot of vehicles on the road that have never had the oil changed in the differential. But, that doesn't mean you should never change it.
    It's good Preventative Maintenance.
    And, it's not difficult or expensive so, I doubt your mechanic is doing it to get more money from you.
    Did you check the owners manual? That should have the schedule for changing fluids.
