gutfelt
Oct 07, 2017Explorer
Kimoreah wrote:
I have a 1999 Harney Coachworks Renegade with a Cat 3126 engine. I purchased it with 78,000 miles about a year and a half ago, and just turned over 100,000 miles.
When I bought it the voltage was fluctuating a lot and I ended up replacing the alternator. That fixed it, however I recently noticed that the voltage was fluctuating again and replaced the alternator a second time.
Now the engine will turn over fine but not start. I'm pretty stumped as to why the sudden failure. I tried to check engine codes by turning on the ignition, turning off the cruise, then holding down the cruise set/resume switch - but no lights blinked. Not even the code 55 saying there are no codes.
I would appreciate any pointers of what I should be looking at, thanks!
sounds to me like you left off the power supply wire to the fuel shut off solenoid?? must be contained in the alternator wire harness some how???? leave ignition on and check for 12v at the fuel solenoid
38,770 PostsLatest Activity: Apr 12, 2026
