keepingthelight
Jan 11, 2014Explorer
CVD wrote:
This is turning out to be a difficult day for simple tasks (simple the last time I did them). I now have a fuel canister that won’t stop draining.
I replaced the paper filter cartridge. Very simple: Lift the vertical drain lever (on the side of the canister), let fuel drain into a bucket for a minute, twist off cap (with 1/2” ratchet), pull out old paper filter and large o-ring, insert in new filter and o-ring, put cap back on, lower lever, and ready to prime/start it up.
The problem is when I turn the key to activate the fuel pump and start priming, fuel pours out the drain at the bottom of the canister (even with the vertical drain lever “down”).
I did break off a cap that was on that drain outlet. When I was first feeling around for the drain lever, I felt the plastic cap over the drain. Thinking it was something that should come off, I twisted it. It broke (crumpled). But, it looked like it was simply a dust cover of some sort.
Here’s the canister. You can barely see the drain lever on the right side:
Here’s the canister from the bottom The drain is at the bottom:
Anyone else had problems with the "drain continuing to drain” after a filter change?
Thx,
Not sure what type of MH you have. Fleedguard filters are usually on Cummins, if so you may want to give them a call.
CUMMINS PACIFIC, LLC (02074)
3061 S. RIVERSIDE AVE
BLOOMINGTON California 92316-3527
United States
Tel: (909) 877-0433
Fax: (909) 877-3787
38,778 PostsLatest Activity: Jun 04, 2026
