Passin_Thru
Apr 15, 2013Explorer
Fill the filter with diesel and put it on again with key on so electric pump is running while you do this, crank engine and see if it will start. Repeat. Don't use WD 40 as it's a solvent and washes down cylinder walls and rings. It should sputter some and don't quit as it will pick up the fuel and expel the air. It is a self bleeding system but a slow one. I owned CAT powered Peterbilt.
38,778 PostsLatest Activity: Jun 06, 2026
