prism
Oct 08, 2013Explorer
devildogg wrote:YC 1 wrote:devildogg wrote:
Okay, all of the fuses we blown on the converter. I replaced the fuse and they blew as well. The batteries are wired in series correctly. Something along the way is not correct. Any more ideas?
Thanks
Yes they may be in series correctly BUT do you have the NEGATIVE side of the battery going to ground?
DO NOT LET THE COLOR OF THE WIRE FOOL YOU. Black wire does not always mean negative.
Secondly, Are you positive the bat. Count the caps. 6 volts will have three. 12 volts will have 6. Even if they are sealed you can pop the caps and count them.
You Sir, are the award winner! That is exactly what happened. Had
I wiped of the ends a little better and not been a touch color blind it would have gone much smoother. Thanks to everyone for the information, sometimes a man can loose control of his environment. All is well now, thank you so much.
Regards,
OB
Actually all of us that told you that wires were crossed are all the award winner
38,707 PostsLatest Activity: Feb 28, 2025
