chucl66ExplorerNov 11, 2013Changing coolant 2000, V10. Help!!!HI, I want to change coolant in my V10. I know it should be 50/50 antifreeze/ distilled water. When I drain system, I only get 3 gal. of the eight it holds. I know that it is not possible to drai...Show More
rgatijnet1Explorer IIINov 11, 2013Did you open the valve that directs water to your dash heater coil?
Related ContentChanging Coolant System Flow Path Plus Electric FanCoolant Changecoolant temperature changedcoolant changeChanging coolant in V-10
