time2roll
Nov 11, 2013Nomad
I would rinse it again with distilled water for starters. Get 20 gallons from the warehouse store. I would have recommended this from the start.
Then pour 4 gallons of antifreeze in while it pushes the water out. Top off with distilled or 50/50 antifreeze depending if you seem to lose any antifreeze in the process.
You can check the mix with a tester from the local autoparts store.
38,778 PostsLatest Activity: Jun 05, 2026
