chucl66ExplorerNov 11, 2013Changing coolant 2000, V10. Help!!!HI, I want to change coolant in my V10. I know it should be 50/50 antifreeze/ distilled water. When I drain system, I only get 3 gal. of the eight it holds. I know that it is not possible to drai...Show More
jcthorneExplorerNov 11, 2013There are 2 drain plugs on the sides of the block. Usually hex key pipe plugs. Are you sure your coolant capacity is 8 gallons?
Related ContentChanging Coolant System Flow Path Plus Electric FanCoolant Changecoolant temperature changedcoolant changeChanging coolant in V-10
