- Gonzo42ExplorerOK...let's see. In order to convert Whitworth to Metric...
- PeterrrrrExplorerYou could consider, getting an OBD reader with bluetooth, use an android app like torque, and you can display everything on the tablet you choose in metric/imperial or both.
- Johno02ExplorerAfter reading your original post, I realized that you said you don't have steering wheel controls. Does that mean that the gauges have the numbers and KPH markings painted on? From what I read in the book, that may not be an option to change. Sorry.
- 2oldmanExplorer II
Cousin_Eddie93 wrote:
Ok OP.. so we can stop getting these kinds of responses, PLEASE tell us what you're asking for..!!
Or just multiply 1.8 times the centigrade value and add 32 to that total.Example: Convert -40 C to F -40 C X 1.8 = -72 + 32 = -40 F - Cousin_Eddie93ExplorerOr just multiply 1.8 times the centigrade value and add 32 to that total.
Better have your arctic package for that one! - 2oldmanExplorer II
Wandering view wrote:
I see you've gotten responses you probably didn't ask for, but I really don't know what you're asking.
Any way to change to mph etc. tired of using conversion app. Thanks
You want to change the actual gauge readout? - Johno02ExplorerIt is set in the settings on your digital readout. Here is a link to the owners manual with details on how to set it. Good Luck, and always remember, when all else fails, RTFM!
link to manual - BobboExplorer IIIDouble, subtract 10%, add 32.
100 * 2 = 200 - 20 = 180 + 32 = 212
Multiply by 9, divide by 5, add 32.
100 * 9 = 900 / 5 = 180 + 32 = 212
Those are EXACTLY the same, just worded differently.
(Multiply something by 9 then dividing by 5 IS 10% less than doubling. Always.) - Johno02ExplorerCheck your owners manual. There is probably a set-up feature to change the reading. Funny thing, our HHR is the same way. it has numbers, and a small light that indicates MPH or KPH. it can be changed as one of the setup options. if I am moving when I change it, the speedo needle will jump from one value to another. The numbers don't change, just where the needle points. The Temperature readings and odometer readings change at the same time. real easy to change, just read the book. BTW, don't bother asking the mechanics at the dealer, they probably don't know either.
- RambleOnNWExplorer IIFor Kilometers per hour to MPH, multiply by 0.6.
As a side note, sometimes I find myself wanting to convert English volume units to Metric. For that I use that widely known conversion factor 5.7 L = 350 cu. in...
38,766 PostsLatest Activity: Jan 10, 2026
