DrewE
Nov 20, 2015Explorer III
Do you have any previous maintenance records?
If not, it's probably best to assume that the fluids need changing. (Don't forget to also include flushing the brakes and changing the brake fluid!) You could get the advice of a trusted mechanic on the work needed.
Also check the date codes on the tires and inspect/replace them as appropriate. Most motorhomes require new tires due to aging long before the tread becomes too worn down.
