- msmith1199Explorer II
- jtfconsExplorerI know on my set-up it's neccessary to undo the exhaust pipe hanger for the generator and swing the pipe out of the way to get the hinged door all the way open. I have also found it better to remove the two screws that hold the door to the hinge and get that totally out of the way. Gives better access.
- JR45ExplorerThis may help
http://www.youtube.com/watch?v=CxqkHAAH818
JR - RaymonExplorer
rbanuchi wrote:
Everyone , thanks so much for your input. It's truly appreciated I have a stupid question though. When refilling the oil, does it get filled directly into the spout on top There are two spouts one for oil and a second one slips my mind at the moment. Thank you again !
You add the oil into the dipstick tube. The other tube is for the coolant.
Ray - rbanuchiExplorerEveryone , thanks so much for your input. It's truly appreciated I have a stupid question though. When refilling the oil, does it get filled directly into the spout on top There are two spouts one for oil and a second one slips my mind at the moment. Thank you again !
- YC_1NomadThe filter can be a bear to remove so buy a new filter and a tool that goes over then end of the filter that you can run a 3/8 inch extension to and use a ratchet. Do not overtighten the new one. Just snug and then about 1/4 turn.
- SnomasExplorerI took my oil filter to Napa auto parts and they gave me a matched filter to replace the original Onan filter. I use Shell Rotella 15-40 in the engine and the Onan Gen set. I put in 2 1/2 qts and run generator several minutes and then check and top off. Don't over fill!! The manual says to replace the coolant plug every 2 years and you can buy @ any cummins dealer.
- RaymonExplorer
JackMS wrote:
Remember to wipe a little clean oil on the new filter gasket.
Also make sure the old gasket came of with the old filter. My Onan owner's manual states the the new filter may be a little smaller than the original filter; my replacement filter was slightly smaller than the original filter.
Ray - JackMSExplorerRemember to wipe a little clean oil on the new filter gasket.
- barnaclebillExplorerThe access door to the oil filter is hinged, just push the 2 release tabs with your fingers to open. The drain plug is labeled "oil drain" It is easy to do, go for it! I hope this helps, Bill
38,769 PostsLatest Activity: Mar 31, 2026
