j-d
May 10, 2017Explorer II
I already had a Dozen-Ton jack about like you linked. It's an old commercial one, Blackhawk brand. In case you were wondering, a Four Ton "Can" lift a rear corner of a Class C, but it'd take more push on the handle than we can produce on a reach. What I don't know about a single-piston 12-ton, is IF it goes "short" enough to get under the axle under flat-tire-side-of-the-road conditions.
I carry my own old 12T because I didn't know any better. If you're starting out new, and want what's sure to work, return the single piston and get a Two Stage. By the same logic, don't get a single piston "Shorty" that will fit under the axle with a flat, but might not lift high enough to install your spare.
Your simulator pix look like our Dicor sims. I say that because they don't have a separate center piece like the Pacific Dually sims in one of the links above, also because the pattern of the hole for the front valve looks like ours, and the starburst image in the center.
Look at your simulated Lug Nuts carefully. Of eight nuts with six wrench flats each, I think you'll find that two nuts have marks on two sides. If that's the case, remove one of those nuts (front is easier without socket and extension) and get a deep socket in that size. Again, I think 1-1/8".
38,779 PostsLatest Activity: Jun 16, 2026
