I am currently running Goodyear G670 275/80R/22.5 tires on my MH. I plan to replace them with Toyo tires. The problem is that Toyo does not sell that size. Does anyone know the best replacement size f...
I changed over from the Goodyear G670 275/80-22.5 to the Toyo 295/75-22.5. The difference is so small you won't notice, almost identical in dimensions. I've found little difference, but make sure you go for the M-154 in load range H.
Here's a profile overlay of the differences along with the numbers.
