Gjac
Mar 12, 2014Explorer III
Dave as Bud said you have to remove the whole door to get to the back. The door has 8 screws to remove. The folks that say it is easy have the kind that have 3 screws for the city valve and it is inside of the water compartment. If you can't find a replacement door assy I would remove the door assy then remove the city valve and replace it with the 3 screw type. You may have to use a hole saw to remove the old valve. You can tell once the door assy is removed.
38,776 PostsLatest Activity: May 14, 2026
