- Dale_TravelingExplorer IITo keep everything happy and confusion at a minimum connect the charger to the same posts that the feeds to the coach are connected along with positive of the charger to the positive of the coach,,,
- rgatijnet1Explorer IIII assume that you have your batteries hooked up to provide 12 volts to your coach. If you hook up the charger at the same point where the 12 volt output is taken from, there should be no problem at all.
38,749 PostsLatest Activity: Sep 03, 2025
