theoldwizard1
Feb 14, 2018Explorer II
If you are simply recharging your house batteries, current (amps) DOE NOT MATTER MUCH (unless you are in a hurry to put a big bulk charge into your house batteries).
The MOST important thing is HOW MUCH VOLTAGE IS RECEIVED AT THE HOUSE BATTERY CONNECTION ! More amps does NOT help this issue. On most vehicles, there is NOTHING you can do to a standard charging system that will really help. Larger wire helps a little.
The bottom line, YOU WILL NEVER BE ABLE TO COMPLETELY RECHARGE A HOUSE BATTERY BANK BE HOOKING IT UP TO A VEHICLE CHARGING SYSTEM !
