kemer's avatar
kemer
charging batteries
I need to put a charger on my house batteries. There are 2 batteries that run in parallel. The fluids are all full. The charger I have will charge AGM, STD, or GEL batteries. I'm assuming these would be STD batteries? Also, with two batteries, there are two positive posts and two negative posts. Do I attach to two of the posts on the same battery? Right now, my voltage meter shows around 5.00 on each battery.
THANKS
BTW, what are AGM and GEL batteries?
