You needed to specify whether the fridge is an RV type, cooling on propane or using 110vac power from the house battery(s) through a converter. A 110vac fridge draws a lot of current because of it's compressor, etc. (run time may be only around four hours. If you are using a typical RV propane fridge and little other 12 volt items, you may get 3 days before lights go dim and  battery is "dead". Battery capacity depends on the age, condition, and whether battery(s) have been kept charged, not overcharged, and electrolyte levels above the plates. Batteries may need replacing at around 10 year mark give or take.
