Eskinsh
Jun 29, 2023Explorer
Charging house batteries
Hello
Im not yet sure if my power converter/ chargier is going/gone kaput, i was dropping below 12 volts, on my last trip amd it didnt seem to be re-charging. My batteries tested bad when i got back and i replaced them.
My question, if I am at a park with electric power and This happens again, i believe I can charge the batteries via external battery charger before they go too low.
Do i habe to charge each 6v battery individually, pr just hook the charger across the pair and charge both, my charger senses 6/12v and adusts.
Im also not clear if i need to disconnect the batteries from the coach wires to charge or I can leave hooked up so my fridge and lights dont die while re-charging.
Thanks in advance!
Thanks in advance!
