CA_Traveler
Jun 26, 2014Explorer III
You could do something similar to a MH. Connect the batteries with a continuous duty solenoid. Then it could be activated with a manual switch and/or ignition.
OR use a BIRD electronic module so that if either battery is charging the other will be charged as needed. This is ideal as both banks are charged from the charger, alternator or solar and manual activation can be added.
