gb71631's avatar
gb71631
Charging Problems Freedom 458 Inverter/Charger
Needing help... I have a 2006 Gulfstream Friendship G7 with a Freedom 458 Inverter/Charger that's not charging the batteries.
I have went through all of the diagnostic manuals and everything has passed including the resistance if the 1/4 amp fuse was blown. I have checked the voltage coming out and it's exactly what it's supposed to be, but still not charging batteries.
I can unplug the shore power and plug in a charger to the batteries and they will charge OK with no problems...?
Any Ideas.....?
  • enblethen wrote:
    Don't get confused about the fuse. It is not a small automotive. it could look like this.
    Fuse
    Our's looks like THIS
  • Don't get confused about the fuse. It is not a small automotive. it could look like this.
    Fuse
  • What remote panel do you have?
    It should show
    * Battery voltage
    * AC input status
    * AC Breaker size
    When on shore power with the charger enabled what is the battery voltage?
    It should quickly jump to 14Vdc or so if not, check for AC input status and Charger enabled status.
    If the panel says all is good with no error codes.
    Suggest you remove the unit from the rig and do a bench test - many times the internal transfer switch craps out.
    PLEASE do not toss it in the trash if you decide to purchase a new unit. As I collect them for spare parts and repairs as time allows
  • What does your Freedom Panel say?
    Does it show Charging, what is the voltage output?
    You should have either a BIRD or BCC, which controls a Isolater relay.
    Look closely at the B+ terminals or the batteries (12 V to Ground Terminal), do you see a Wire with a fuse. Is it clean?
    This wire is the sensing voltage which informs the BCC or BIRD that the charge voltage is at a high enough level to close the Isolator relay.
    Do you have a diagram?
    Also, read the voltage on the Red & Black terminals of the Xantrex, is it above 13.5 Volts. Trace the wire from the red,
  • enblethen wrote:
    Have you located the large fuse in the 12 volt DC line to the batteries?
    The 'fuse' may actually be an automotive type circuit breaker. With either shore power connected or the generator running, check the voltage across the negative and positive terminals of the batteries. You should be getting more than 12VDC; probably 13.5+ VDC. If not, connect a jumper wire across the breaker and then again measure the voltage across the battery terminals. If the voltage increases above 12VDC, then the breaker is defective. Breakers are available at most auto parts stores for $10 to $15. Hope this helps.
    yep, that is what I would guess.
    rig a test light, and use it to jumper the big fuse while trying to charge the batteries, If it lights replace the fuse.
    NAPA has a replacement for $10
  • Have you located the large fuse in the 12 volt DC line to the batteries?
