pianotuna
Sep 10, 2016Nomad III
15 amp shore power with a power factor corrected charger will output up to 125 amps @ 12 volts (nominal).
If you have plans for using an inverter you could go to an inverter/charger and use that for high rate charging.
I simply unplugged the OEM converter from 120 volt supply and left it in place as a back up.
38,782 PostsLatest Activity: Sep 10, 2026
