booster
Sep 11, 2016Explorer
4gnomad wrote:
Hi all, I've been diving back into how to upgrade my battery system in my class B and was hoping someone here could sanity check me. I have a small 100AH 12V coach battery and I'm upgrading to a pair of L16s (6V, 400AH). My RT has the old MagnaTek charger, which is rated at 32A, but the charging circuit to the batteries is fused at 15A.
The L16s accept up to .25C, so they'll take up to 100A for a few hours before the current drops. I'd like to hit that target to ensure a nice long life for these bad boys and prevent sulfation. Obviously that's not going to happen over a 15A circuit. So here's what I'm thinking:
1. Hook up a Powermax or some other quality 100A charger directly to the battery. I think I can just remove the trickle charger that's in there now (and which I've never used).
2. Pull the fuse on the existing charging circuit so that circuit isn't active when I'm hooked to shore power.
3. When I hook up to shore power hook up both the charger and the regular shore power connection to whatever is available (15/30 is all my rig can handle).
4. From another post I also need to protect the circuit coming off of the alternator so I don't overcharge the AGMs if something goes wonky up front and it starts putting out too much voltage.
My main question is with regard to #3 above - anyone see any problem with me charging the battery and running off of shore power at the same time as long as I've disconnected the original charging circuit?
Last, I eventually want to add a few solar panels so I can "top off" with solar at a lower amperage after running the gennie or hooking up for a few hours to recharge. If I'm reading and understanding the charging profile correctly this is a reasonable thing to do. If I do this do I have to always remember to turn off solar charging when I hook up to shore?
Interesting project. We have 440ah of Lifeline GC2 six volt batteries in our 07 Roadtrek 190.
The first question would be if you are getting the big batteries because you want long time low load off grid capability, or because you want to run high load things through an inverter? If you are going to have a big inverter, the mentioned inverter/charger combination would probably be the best choice, as it will be less wiring and space, plus you get an internal transfer switch. You would also need another auto transfer switch upstream to switch between shore power and generator. If you already have a built in generator, that transfer switch would probably already be there.
I would get rid of the old stuff. Trying to run two chargers is going to be more trouble than it is worth. The original is old and probably dirty power besides.
Your alternator in a 1994 may only be running at 13.8 volts or so, which is very safe for charging, but slow. If you have an isolator, that will also drop you .7 volts. The Lifelines will like 14.3v for charging, but you would need to have a disconnect to prevent overcharging. You will also likely need to upgrade the wiring to the coach from the engine, as those batteries will accept way more amps than you current wiring will handle. You could also fry a stock style alternator, as they don't like to run at full output. Per Lifeline, our batteries will pull near 400 amps for the first 10 minutes and settle at near 300 amps until it starts to taper, so you need to have power sources that can run at full output without damage and they will give the current limiting. Remote regulators can be used on an alternator to limit it's output to make it survive, also.
Our Lifelines require over 8 hours of time to get totally full from an over 50% discharge (100 amp charger), so you may be underestimating the time it will take to recharge. The current will start to taper by 70% full and the last 5% can take nearly as much time as the entire rest of the cycle. To take good care of the batteries they need to get totally full every 7-10 charge cycles, and the only good way to know if you are full is with a shunt based battery monitor system. Some of the nicer inverter/chargers have a monitor option built into the remote, which is a clean way to go.
Solar is good way to help at the end of a charge cycle, once the acceptance amps go down far enough. Unfortunately, it does take a lot of time to get the batteries full, so the other sources would need to get you to the solar's capacity quickly, as you might need 6 or more hours of good sun to fully top the last bit of charge. The more solar you have, the sooner you can shut off the other sources like the generator or engine. We have 300 watts. If you get a decent solar controller, it can run off the same battery shunt as the battery monitor does. It should take care of itself without any intervention needed in relation to the other charging sources.
38,782 PostsLatest Activity: Sep 10, 2026
