mtollin wrote:
I think you have that backward.
Meantime I found a marine shop, and although expensive, they made me one bad ass cable even bigger. This one won't break!
The expensive one is the one that failed.
Replacement will last a lifetime and prove lower cost.- jaugustonExplorer2ga is fine for a gas engine MH. 00 would be appropriate for a Cummins or my Cat C-7.
- Sully2ExplorerGet "2 ought" ( 00 size) welding wire and have them crimp the proper ends on for you. Welding wire is VERY flexible...
- bigred1cavExplorerIt is just a starter cable for motor vehicles.
- 2oldmanExplorer II
mtollin wrote:
Good. Now that you're fixed I can criticize you!! :)
You need to inspect those things now and then. AGM batteries won't corrode cables. And for the future, carry spare wires/cables, connectors, crimpers. Never know when needed, and often it's game over until it's fixed. - roam1ExplorerMarine shops Are great!
You can fab your own in any gauge on the spot! - mtollinExplorerThanks to all. I'm up in the mountains and closest auto store is 40 minutes. Made some calls, even Fleetwood was stumped for replacement part or gauge, escalated. Meantime I found a marine shop, and although expensive, they made me one bad ass cable even bigger. This one won't break! A couple of washers and back in business. Thanks for the quick responses. Nice to know there is help out there when it's needed.
- DougEExplorerTractor Supply. Closest to Tampa Bay is in Bradenton.
- Standard auto parts store cables are #4 or #2 SAE wire. Get the #2.
- BobandShazExplorer
2oldman wrote:
auto parts store
Might need size of battery?
38,782 PostsLatest Activity: Sep 10, 2026
