tahiti16
Dec 30, 2014Explorer
Couple things make sure you check the water in the chassis battery, low water will cause faster discharge. 2 make sure and check voltage 10-30 minutes after you disconnect the charger as the battery will show an artificial level right after disconnecting.
3rd if you are really drawing it down that fast either you are using something you don't realize is attached to chassis not the house batteries or something could be miswired causing the extra draw.
As Mr. Wizard stated some have an interconnect some don't and some are just broke.
