bullydogs1
May 09, 2015Explorer II
Once you get good batteries in there...you want a voltmeter...it should start and then put the voltmeter on the batteries to ensure your alternator is charging your batteries from the coach..If that's good a trick l start is in your future..If it shows the alternator is not charging your coach batteries, (no increase to 13.6 or so) then your alternator is bad as well....Start with the batteries..then check alternator.
