zach477
Aug 21, 2015Explorer
Not all coaches are set up for the generator to charge the chassis battery. On the ones that do, a bad voltage regulator could cause it to drain the battery rather than charge it. If it isn't set up to charge the chassis battery, you should be able to last more than a couple days. The battery might be toast.
Where is the sulfur smell coming from? The chassis battery or the house batteries?
38,777 PostsLatest Activity: May 24, 2026
