mc_cc
Jan 10, 2015Explorer
Twomed wrote:
The TS will not overcharge your batt. A house batt connection may cause you over/under charge since that system was not designed to handle both. Many folks use the TS wired permanently as a solution with zero issues.
Thanks, I did not realize this system uses the existing house charging system. I just ordered one online. They give you two options, I ordered the 5 amp option rather than the 15 amp. Hoping it works. I am the third owner of this rig, so I am not sure what has been wired where. Thinking somewhere along the way the starting battery was wired into something in the house and causing it to drain even with the 12 volt system off.
38,769 PostsLatest Activity: Apr 03, 2026
