Cruisineasy's avatar
Cruisineasy
Chassis battery
I have a 31' 2011 Jayco Greyhawk. In the off season it is parked for about 3 months at a time. I try to run the engine and generator at least every two weeks to keep the batteries charged. From time to time I have to go three weeks. I have been loosing the chassis battery about every two years. My question is, would it be a good thing to install a battery disconnect for the chassis battery? Would there be any "side effects" to disconnecting that battery??
Thanks in advance for your help..
Dave
  • The "what is best" depends on what you have available where you store it:
    1. Shore power-- even 15 amp
    2. Solar and not stored under cover
    If answer to both is NO, then disconnect is a good answer. And it is not good to just start and idle and engine-- just adds moisture to the crankcase. While you can get the COOLANT up to temperature at idle, you can not get the OIL up to temperature. So, finding an alternative plan is a good idea. Best if you start it to drive 25 highway miles.
  • Gjac wrote:
    I would not use the engine's alternator every 2 weeks to recharge the batteries. Just charge to full and disconnect the neg cable and your batteries will be fine for 3 months assuming your batteries are good to start with.
    Yes, this is what I do. I unhook a battery cable between trips in the summer, too. The various parasytic loads can drain a battery down to 50% in two weeks.
    Being a little further north, we don't camp in November through April. It gets dark too early and daylight too late, not to mention cold. So I put a charger on the battery overnight once or twice over the winter.
  • Gjac's avatar
    Gjac
    Explorer III
  • I use a battery tender on mine. My chassis battery is the original that Ford installed in '03 and it's still a happy battery.
  • navegator wrote:
    No side effects, also install battery minder to maintain the charge up, provided that you have electric power near.
    navegator
    I keep a Battery Minder hooked up to chassis battery and also my house batteried when coach is in storage.
  • Disconnecting house or chassis batteries would be fine-provided you insured a good full charge before disconnecting. The last 10-20 amp hours of battery charge trickles in at a slow rate-generally longer than a run engine every few weeks regimen.
    Because of the last sentence above, I think best would be a battery maintainer (if power) or a basic solar system without power-both setup to maintain house and starting batteries. Both are reasonably priced alternatives to new batteries every few years.
  • i really try not to disconnect chassis batt. computer loses memory and engine runs horribly for a few minutes when you next start
    just leave the batt tender on
  • No side effects, also install battery minder to maintain the charge up, provided that you have electric power near.
    navegator
