rmerrittjr's avatar
rmerrittjr
Chassis Battery
It seems my coach battery is draining down during the time I am plugged into a 30amp source. After three days of being plugged in a 30 amp source the coach battery was completely dead, the alternative source (two sis volts)does not help in starting the engine. I jumped the batter from my car and drove it straight to a battery shop. The guy checked the battery said it was holding a charge under a load and there seemed to be nothing wrong with the battery. The gage is now showing fully charged. What coud be draining the battery, I have looked at all the storage bins and other parts of the rv and cannot find what is draining the battery. I do have a backup camera and the camera is wired into the running lights so it only comes on when I have the headlamps on, the monitor I assume is wired to the coach battery. would this be an issue, it does not look like it is powered up when the ignition is off. Someone has mentioned it could be the starter, would this cause the battery to die? Any help or suggestions would be appreciated.
