wildmanbaker
Dec 15, 2017Explorer
Are you talking about the end link, upper, lower, or the actual axle mount? The CHF should not cause any bolt failure, unless it has been overstressed, or left loose. These are Metric bolts and nuts, remove the other side and get a matching replacement. If it is falling out, use lock-tight blue.
