mdecastra's avatar
mdecastra
Ford F53 CHF (Cheap Handling Fix)
I saw this string about CHF. Any concerns about going forward with CHF??:
My Ford F53 18,000 lb chassis has two holes at the end of the sway bar. Sway bars work by twisting. That twist takes place between the brackets holding the sway bar to the axle. By using the second set of holes you "wow" is coming from the fact the sway bar is not twisting in that position. You might as well weld a chain to the axle and tie it to the frame. You are pulling on the end of the sway bar because it is almost a straight line between the bracket on the axle and the chassis. All F53 are laid out the same way. Mine is not unique. You are pulling on the axle with the sway bar ends. THINK TWIST when you're looking at it. Now if you moved the chassis mount point and then used the second hole maybe..... Doing it as described is, in my opinion , a big mistake. I would never experiment while on a trip. I've done the Alaska trip on nearly every road in Alaska except the "haul road". If it was rocking that bad, I'd be slowing down instead.
I had high hopes this free fix would work.
