MetalGator's avatar
Jul 21, 2017
Cheap Handling Fix at Ford Dealer
One of the local Ford dealers in our area claim to be one of the biggest F53/Motorhome service centers in the country (Gator Ford east of Tampa Florida). They have a 60,000lb lift and run specials for RV service. I am going to make an appointment soon to get an alignment on our new motorhome. I was wondering if anyone had ever had a Ford dealer do the cheap handling fix. I really enjoy driving the new motorhome but it does have a lot of body roll when taking corners. Before I spend any money on suspension mods I'd like to try the CHF first as long as it doesn't affect the Ford warranty.
Burch
  • MetalGator wrote:
    stvdman wrote:
    I just had it done (front only) at White Marsh Ford in Baltimore..drove from MD to Orlando and back, nice improvement. Going to do the rear ones next time I have it in for service.
    If you don't mind me asking, how much did the Ford dealer charge you for the adjustment?
    1 Hour of labor and $5 shop supplies, total was like $120.
  • jyrostng wrote:
    "I replaced the links with longer ones and that fixed that problem."
    Did you take the longer front (stock) sway bar end links and use them on the rear? It helps as they are an inch longer than the stock rear links.
    No, not yet, I just moved the rear with the stock links, If I get ambitious in this Texas heat, I will. I kept them.
  • Our motorhome is a 32ft 2004 Fleetwood Fiesta on a Ford F53 chassis. I diid the CHF on the front and was hopeing to see good results. Just drove it 120 miles when we would stop or do a turn the springs would hit the sway bar making a very disturbing metal clunking sound. It improved the sway some, but not worth the mechanical problem. I have changed back to the forward position holes on the sway bar. Kudos to this site for its great information from members.
  • Why would anyone drive off-road in such a rugged road condition that the motor home bounce would lift the wheels off the roar surface?
  • I did my front with good results, but a few times the sway bar hit the springs when I hit a pot hole, also a few times when using leveling jacks the bars were laying on the springs as the font tires were off the ground. I getting ???? about this, thinking of going back. A track bar I installed on the rear was the best result of my handling fix.
