OSCBRADLEY's avatar
OSCBRADLEY
Check Antenna Light
So I went out to move my moho and could not start it. Dash is displaying "Check Antenna" light. I believe it is a built in safety feature that prevents you from driving down the road with your tv antenna extended but the antenna is definitely down. Is there a bypass for this like a fuse I can pull?
2000 Itasca Suncruiser 32V
  • I own a 2004 Winnebago, when I first start my coach the Antenna light and buzzer come on for about 15 seconds then go off. It's just a warning device in my coach to encourage you to get out of the coach and look to see if the Antenna is down. The Antenna light and buzzer does not effect the starting of my coach. There is a electrical plug to the device in my coach that you can use to disarm the buzzer and light.
  • Have not tried aux start switch, I will go give that a try. I believe batteries are ok as I was able to drive it last night.
  • You have checked your chassis battery to see if it is charged? What chassis do you have? I really do not believe you have an interlock between the antenna and starting the engine. Have you tried the "aux start switch"?
