mtrumpet
Jul 12, 2015Explorer
imgoin4it wrote:
You will get the same tire wear on the out side of the front passenger side if in need of a front end allignment. I was told same by an individual that had same wear. He had front end aligned several times with no correction. That's when he found many places do not know how to do the allignment on a Spartan chassis. He found a place that checked with Spartan, aligned it correctly and problem solved. I had the same tire wear and asked and found someone who knew how to align the Spartan and it drove better and odd tire wear was also gone. The correct procedure has to do with checking ride height before proceeding with anything else but beyond that I am in the dark. It is well worth checking before you pay for new ball joints.
Thanks for the tip imgoin4it.
You are correct that severe out of alignment will cause excessive and abnormal tire wear as well. In my case though, I know for a fact that the ball joints are on their way out. I'm just trying to gauge the severity of the wear at this point in consideration of the two upcoming trips that I mentioned in my OP.
When ball joints go bad, they do effect the wheel alignment. When they get replaced, as you mentioned, the ride height must be checked and adjusted if necessary. A complete wheel alignment must be done.
38,766 PostsLatest Activity: Jan 10, 2026
