atsrmf's avatar
atsrmf
Refrigerant charge amount, engine air
I have a 1987 Gulfstream Class A with a 1986 Ford 460 driveline. I want to connect a recycler and evacuate the system, vacuum, and then recharge with R-12.
My question is, how do I find out the recharge weight in pounds? There is no sticker on the engine, and I know better than to call the factory for an answer. If I can't find out, I can always charge until the pressures are within specs for the ambient temperature, which would probably be close enough.
The chassis is John Deere and I think the driveline is considered an F-350.
