I had a problem that when the master cyl was installed (new), apparently the pedal linkage was a little tight (definetelly had clearance for free play COLD), BUT shen heated the gap was filled and the very little hole in the bottom of the tank in the master cyl was restricted, hence freezing the front brakes, in which produced more heat, more restriction, and LOCKED UP front brakes! I was able to pull over and oppened the front calippers bleed screws, one of them let go with a squirt and unlocked the RV.
I called my mechanic to protest about the brake job, he said that that particular caliper design gets very easilly "ovaled" and grabs the piston (I understand that you did NOT changed or serviced the calipers), after that poor explanation, I had to continue my trip, the brakes had cooled by then, I increased the free play of the pedal and the hydroboost, and make shure the rod between the hydrob, and the main cyl was IN THE INTENTED SOCKET, Not kinked or resting on the piston edge of the main cyl... ans sure enough' after a few blocks I started to feel brakes grabbing again, in desesperation (and anger perhaps) I pumped hard and rapiddly the pedal, suddenly, the front brakes RELEASED With a CLANK!!!, (ohhh-s!), but the brakes DID work as supposed!!!!!, few miles ahead, same grabbing feeling, pumped the brakes, fainter and easier clank.... worked as supposed..... one last time few miles ahead, and released again w/o noticeable clank, and never again in a trip >1200mi, perhaps some rust in the piston area, and USE had "fixed" the issue!!!
