Had to replace my front rotors and pads and master cylinder. Bled all wheels and all working fine. Then they started dropping again to the floor. I noticed last trip after a hard climb through the nev...
You need to find out why the exhaust is getting red hot. Are they stock manifolds? Are you trying to go up the grades at full speed? You may needs to adjust your driving habits! I would believe that heat builds up in the rubber lines closing them off. This is common.
