Had to replace my front rotors and pads and master cylinder. Bled all wheels and all working fine. Then they started dropping again to the floor. I noticed last trip after a hard climb through the nev...
Got a different style of fan clutch from AZ. It works correctly, starts to kick in at 200 and is fully engaged at 210 to bring the temp back down to 195 then starts to cut out. It is a slightly different construction than the first one from AZ and the follow up one from Napa, both of which failed. AC Delco parts are now made in the big C so no different quality than those at napa, AZ or O'reillys. Noticed this last trip that the hydro boost is leaking from the front, guess time to replace it.
