- BoogiemachineExplorerI haven’t but I’ll check now. Thanks
- ArchHoaglandExplorerI have two friends whose RV had engine rodent damage.
Their insurance companies covered the repair.
Have you checked with your insurance company? - HorsedocExplorer IIDid you every determine what animal chewed it, or what happened? Cannot imagine what creature would be wanting to chew gasoline vapors.
- BoogiemachineExplorerSo it looks like one of the brushes of the regulator was sheared. Just rebuilt it and I’ll test it tomorrow. Thanks for all the help!!!
- RLS7201Explorer IIIf you alternator is truly flucting after using a voltmeter. I suspect the voltage regulator is failing. It is mounted on the back of the alternator and is easily changeable without removing the alternator. If you elect to remove the alternator, the bottom bolt will be corroded in the aluminum hole and will require considerable effort to get out. Once loose the bolt will slide very tightly next to the radiator fan shroud, but will come out with effort.
You have already been given good advice on your charcoal canister.
Richard - DFordExplorerHere's a picture of a Ford charcoal canister for comparison to what you're showing:
- opnspacesNavigator IIIThose look like vapor canisters. The vapor canisters capture the fuel vapor as it expands in the fuel tank and absorbs it into some activated charcoal. At some point in time a solenoid opens and allows the engine to suck fresh air through the charcoal in the canister and pull the vapor into the engine to be burned.
The chewed canister will not cause the alternator problem. My guess though is whatever animal chewed on the canister also chewed on the alternator wiring. And for what it's worth, I'm betting that is the bottom of the alternator just above the canisters in the picture. - BoogiemachineExplorerSorry it was quite hard to figure out how to post an image here you go
Yes all the connections were checked and I cleaned up the battery terminals. chassis battery is bouncing from 14-16.2
- DFordExplorerWelcome to the Forum,
Posting Pictures on this Forum Explained
The more information you provide in your questions, the more helpful the answers will be. - azrvingExplorerMaybe some of the wiring has been chewed on.
38,770 PostsLatest Activity: Apr 12, 2026
