With grandkids in carseats our coach only had seat belts in the front two seats the couch and the recliner so no forward facing except the 2 front. Nothing suited for carseats so I added seat belts to the dinette, not as easy as it sounds. All of the available attachment point we just wood not suitable for an anchor point. So I ran angle Iron from steel slide brace to inside slide frame and used that to anchor cables that I fastened the seat belt to, the cables can also be used to fasten the car seat directly without the use of the belts. I installed the cable because the seat belts I had we not long enough to bolt directly to the angel iron. I added them to both seats of the dinette for use as the boys get older.
