- DrewEExplorer IIIIf the converter is original equipment still, it probably hums more or less when it's plugged in. Maybe you can listen carefully for a 60Hz hum and see where it's coming from. Quite often (but certainly not always) the fuse panel and AC circuit breakers are at the same place, or very close by.
- 77rollalongExplorerhave to start looking in all the cupboards , normally with the 110v fuses, and the converter, sometimes under the rear bed.
- AvaExplorerThey should be somewhere inside. Have you looked in every space high or low or in the back of a drawer or bottom cupboard? Good luck
38,774 PostsLatest Activity: May 14, 2026
