luvz2cook - Christine welcome to the forum.  Not sure what model you bought, but our model 211 has the pump and fresh water tank under the dinette seat.  There are two valves next to that pump.  One that looks like an old radiator drain valve
 that drains the fresh tank on the ground.  The other one has a ring that you pull up on to drain the water lines for winterizing (low point drain).  This one often times has to be pushed back down.  I suspect that this one is not pushed down and seated so both the pump and shore water is being poured on the ground under your rig.  :)
