luvz2cook wrote:
That's what I need to hear!  Thank you! I was not familiar with the valve with the ring that you pull up on!! Got dark before I could figure it all out, but will fiddle with it today...trying to sanitize the tanks and check all systems on new toy....thanks again!!
  City water fill valve must need replacing...will not take in any water....
the city water fill has an internal check valve (closes when using water pump).
They are just cheapo plastic junk.....plunger/spring/o-ring.....and can get jammed or o-ring falls out of position.
Check valve is probably jammed but also check that the screen/washer in the connection (garden hose washer with a screen) is clogged up with debris
