dakdave
Sep 30, 2013Explorer
To answer your question,fuel pressure is not required to have spark from ignition. There has to be a signal from ignition to fire injectors. If you have no spark from coil i would suspect bad module or pickup coil in distributor.
Good Luck Dave
Good Luck Dave
38,782 PostsLatest Activity: Aug 23, 2026
