enblethen
Sep 30, 2013Nomad
Fuel will only squirt if the fuel pump has applied sufficient pressure to the line.
If the fuel pump relay has not run for the two seconds, there will be limited pressure.
In "run" position the fuel pump will not run with out oil pressure.
38,782 PostsLatest Activity: Aug 23, 2026
