Daveinet
Oct 01, 2013Explorer
GeorgeFl9483 wrote:OK, I want to make sure I understand your answer. By injector pump, do you mean that the injectors themselves click? Is it safe to assume you do not hear the fuel pump, as it is in the tank?
The injector pump is heard when key is turned on, and before engine is cranked. The distributor cap, rotor, coil, and module in the distributor have been replaced.
Incidentally, if the coach has been sitting a while, the pump may not run long enough to get fuel all the way up to the injectors on the first try. Yes, there should be a check valve in the pump that would prevent the fuel from running backward down the line, but it may still leak back slowly.
38,782 PostsLatest Activity: Sep 10, 2026
