MotorPro
Oct 02, 2013Explorer
Daveinet wrote:He never said the pump doesn't run, he said there is no spark from the coilTrail-Mate wrote:I'm sorry, I disagree with you. There is not any sensor anywhere on the chassis that will prevent the pump from pumping fuel when the ignition is first turned on. This is a pre-start condition that is commanded from the ECM, to provide fuel in preparation for the engine to start. This occurs regardless of if the engine turns over or not. Same with the injectors. The injectors are pulsed initially, regardless of if the engine turns over. Basically, they put some fuel (rich mixture) into the intake so when the engine cranks, it will start.
On the TBI GM Motors the module in the distributor will cause this issue. Random starts then No start at all. Easy to change and not expensive. If this does not solve it then connecting a fuel pressure gauge to the port in the rear of the TBI to test Pressure. Peak Pump pressure on the TBI motors is about 15-16 psi, and regulated by a regulator in the back of the TBI, There are way to change the regulator pressure but would have to look up how to do it, but the regulator is not your problem anyway.
See, if we hear the injectors fire when the key is turned on, then we know there is power to the ECM. Right now, we have no proof the ECM even has power. As a matter of fact, there is some indication that the ECM is not getting power, because of the lack of fuel when the key is first turned on, as well as the lack of spark, once the engine is cranking. So, that is the reason we want to listen for the injector pulse when the key is first turned on (before cranking). If we do not hear that injector pulse, then the ECM has lost power, and all these other symptoms are secondary.
38,782 PostsLatest Activity: Sep 10, 2026
