tropical36
Oct 23, 2016Explorer II
gatorcq wrote:
call cummins support.
All Class A Diesels engine are computer controlled PERIOD.
That being said, when you turn the key to off the computer then turns off a valve which is spring loaded. Thereby chocking the fuel off
Maybe you can enlighten me here.
I have a Ford type or standard solenoid back by the HEUI fuel pump, but also could be for the air compressor. Just trying to figure out, with what you're saying here and if this solenoid is what actually shuts off the fuel. If so and to work like you're saying, it would have to be a continuous duty type for holding the valve open when the engine is running. You can easily see it in some of these photos.
Cat engine pics
A better closeup of it here... Solenoid
