Mile High wrote:
I don't understand how that damage (which you have showed many times) is related to the fiberglass roof. Sorry, but fiberglass doesn't leak or a lot of boat manufacturers would have some issues right now :). There are no seams on the roof (it is 1 piece), so it was leaking at one of the seals - actually it looks like the skylight. How can that be blamed on fiberglass, as it would do the same thing with any membrane roof.
Quote:
2001 Winnebago questionable roof design ... there was a roof design change in late 2001, when Winnebago started overlapping the fiberglass roof edges under the edge
nothing to do with the roof design and was changed as I posted it was the roof joint where it met the sidewall and long since corrected
